fuel injectors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2011, 07:30 PM   #1 (permalink)
View fuentes180's Photo Gallery
fuel injectors
hi, i changed my 96 rolla fuel injectors. i replaced them wit a v6 camry ones. and the check engine light came on. should i worry bout that? and by changing the injectors, will a get bad mpg?
thanks
fuentes180 is offline   Reply With Quote
Old 06-15-2011, 08:12 PM   #2 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $142700
View Piloter's Photo Gallery
Oh god, are those even the right impedance and flow rate? Or anywhere close?
WIP AE102.
Piloter is offline   Reply With Quote
Old 06-15-2011, 10:11 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
what were you trying to accomplish?
Old 06-15-2011, 10:27 PM   #4 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
Stock ECU won't be able to compensate for the new cc injectors without engine tuning which I doubt there is.
You might be dumping a bunch of fuel inside the combustion chamber washing your rings out. I'd change those out and put in your old ones if they're still in working conditions.
204whp/157wtq
Nusdogg is offline   Reply With Quote
Old 06-15-2011, 11:57 PM   #5 (permalink)
alright so screw that plan...-____-
thanks guys,
so what can i do for a better acceleration response and hp?
Old 06-16-2011, 03:52 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Its called MAINTENANCE.
Just do what you are supposed to do... plugs, wires, etc..
If its still not enough, then you need to consider a blacktop engine.
-SP
Old 06-16-2011, 09:43 PM   #7 (permalink)
DOHC VTEC
^^ x2 on the 4AGE BT!
204whp/157wtq
Old 06-16-2011, 10:35 PM   #8 (permalink)
on full afterburner
Gameroom cash: $1345097
Or if you like turbocharged goodness, 3S-GTE swap.
