1995 prizm/corolla code jumping - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2011, 09:01 PM   #1 (permalink)
View usa_sera's Photo Gallery
how do you jump the ECU to read the codes?
usa_sera is offline   Reply With Quote
Old 06-15-2011, 10:11 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
TE1 to E1
Old 06-15-2011, 10:28 PM   #3 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
Sweet, I needed to do this to my '95 Prizm as well. I knew what it is already too, but just didn't know how to jump it for future references.
204whp/157wtq
Nusdogg is offline   Reply With Quote
Old 06-16-2011, 12:10 AM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
To read the codes on an OBD-I system, all you need is a paper-clip
Look in the engine bay and you'll see a small black box next to the left hand side strut tower that says 'Diagnosis' on it. Get a paper-clip or a small piece of wire and put one end into the port labelled TE1 and the other end into the port labelled E1 (the labels are found on the underside of the diagnosis box cover, much like a fuse-box).
Turn the key to the 'ON' position, but don't start the engine. If your connections are correct then the check engine light should start flashing. Keep note of how many times it flashes as this is the code it is giving you. For example, if the code was 35 it would flash 3-times, have a short pause, then flash 5 more times, then have a long pause. If it repeats the same code after the long pause then that means it's the only fault detected, but if it flashes for a different period of time then that means there is more than one fault. Take note of any codes it's giving you.
The meaning of the codes are as follows:
12 = RPM signal (no RPM signal to ECU within several seconds after engine is cranked)
13 = RPM signal (no RPM signal to ECU with engine speed above 1,500rpm)
14 = Ignition signal (no ignition signal to ECU)
16 = ECU control signal
21 = Main oxygen sensor
22 = Coolant temperature sensor
24 = Intake air temperature sensor
25 = Oxygen sensor or circuit (lean)
26 = Oxygen sensor or circuit (rich)
27 = Sub-oxygen sensor
31 = MAP sensor
41 = Throttle position sensor
42 = Vehicle speed sensor
43 = Starter signal
51 = Switch condition signal
52 = Knock sensor signal
53 = EGR system
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
texrex (09-17-2011)
Old 07-20-2011, 10:20 AM   #5 (permalink)
Hilux lover
View Kevinpiersonandson's Photo Gallery
I pulled codes while I had the head off. No probs. I disconnected battery and completed head project. Reset all circuts to ECU by grounding out (+) batt cable. Now I cant get any codes, no light on dash, no O/D light, just a battery and seatbelt light. Any ideas?
Kevinpiersonandson is offline   Reply With Quote
Old 01-20-2012, 06:07 PM   #6 (permalink)
View Judge2's Photo Gallery
Just steady flashing of CEL light. No light on previously.
Been a while since I checked a car's computer with a paper clip. haha.
Though your instructions are good, the diagram is not to clear about where to put the paper clip. I felt confused or dyslexic when trying to figure out which spots were TE1 and E1, so I've got some doubts if I did the connection correctly.
Anyway, I just got a constant blinking CEL. There was no long and short pattern. Previously the CEL was not on.
Judge2 is offline   Reply With Quote
Old 01-20-2012, 07:46 PM   #7 (permalink)
Bitter's Avatar
That's correct if there is no code stored, it just blinks.
