wildman,
Spark is the easiest to check and a good starting point. Fuel/injectors is more difficult without the proper tools/guages. When I was chasing a miss and was concerned about fuel supply, I did pull the return line just past the pressure release valve. You need something of size to catch the fuel and it doesn't take long if pressure is correct. I was using the bottom portion of an old milk jug and it seems like it took about 10-15 seconds to put a couple of inches of gas in it when the car was running.
I've not put numbers to it, but the fuel must make a hundred or more trips to the motor before it finally gets burned
Do you know when the timing belt was last changed? If it was original, you may have shredded it. I understand these to be non-interference motors so a new belt would likely get you going again, but, I have read a few posts that would indicate it may not be that simple.
Chris
