94 Rough Idle when lights or AC are on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2011, 11:37 PM   #1 (permalink)
View dantheprintman's Photo Gallery
Hi all my name is Dan, and I am new to this forum!
For about 2 weeks now my car (A 94 Corolla 1.6lt 5speed with 145k miles) has been having a very rough idle. The strangest thing about the idle, is that it becomes worse when my headlights, or AC are turned on. Any suggestions, I am not sure what other information I should be giving. So please ask away. Thanks in advance!
dantheprintman is offline   Reply With Quote
Old 06-25-2011, 11:09 PM   #2 (permalink)
View NWMO 95 Prizm Lsi's Photo Gallery
Hello Dan,
Not a lot of info, but from what you have shared, I would want to check the alternator. It sounds like the alternator does OK with minimal load, but when you start using the high amp items, it likely pulls the voltage down on your ignition system, causing a puny spark and rough idle.
Chris
NWMO 95 Prizm Lsi is offline   Reply With Quote
Old 06-26-2011, 12:13 PM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
99% of idle problems are with the idle control valve. Usually it just needs to be cleaned.
-SP
