Realistic MPG Expectations? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2011, 07:05 PM   #1 (permalink)
ToyRolla97's Avatar
View ToyRolla97's Photo Gallery
Ok folks, here's what's going on. I had an '07 Corolla LE until I got laid off about a year ago, and now I'm sporting a '97 Corolla CE. I was used to the mileage I was getting from the '07, about 36MPG. The '97 Has the 4AFE with the dreaded 3-speed auto tranny, which I understand won't give me the best MPG, but I've learned to deal with that. However, I recently got a different job which is all city driving, and the '97 went from getting 25MPG with a city/highway mix, to getting 17. I do have a small hairline crack in the manifold, and I understand that can sometimes disturb the sensors and therefore the MPGs might be lower, but otherwise I just did a tuneup 15k ago, including new plugs and wires, etc.
... so what I'm asking here is this: is 17MPG really what I should be looking at? That seems disturbingly low, especially for a Toyota.
Any advice is welcome.
ToyRolla97 is offline   Reply With Quote
Old 06-27-2011, 07:18 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
You definitely have a problem. WHile the combination you have has been cited many times as having the worst mileage it should be better than what you have. There are a LOT of factors that affect mileage. You just need to work at it to find the offending parts.
-SP
Old 06-27-2011, 07:22 PM   #3 (permalink)
ToyRolla97's Avatar
Thanks for the reply. It has been a work in progress, I've done a lot of work to the car since I bought it, the biggest of which was the tune up with the new plugs, as well as suspension work (new shocks all around, new tires)... Could a bad O2 sensor cause this? Is there a way I can test that or would I have to bring it in for someone to look at? I'm thinking at this point it's either a bad sensor or a fuel injection issue.
Old 06-27-2011, 08:26 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Bad O2 sensor usually causes a CEL. You can check output on millivolts with a good meter.
If you are running 17 mpg rich the plugs should be almost solid black and a nice black cloud following you.
Dont overlook another obvious problem- fuel leaks. Lines are well known for rusting out.
I always do a leakdown test on every engine to make sure it has no issues with valves or rings. That way I KNOW the engine has potential to run correctly.
-SP
The Following User Says Thank You to speedy25 For This Useful Post:
ToyRolla97 (07-15-2011)
Old 06-27-2011, 08:35 PM   #5 (permalink)
ToyRolla97's Avatar
-SP
I do get a bit of white smoke from time to time, but I was sure if the car was running rich I'd be able to smell it, if that makes sense.
I'll have to check the lines, and re-check the plugs... never really gave that a second thought.
Thanks for all your input bud!
Old 07-15-2011, 12:03 PM   #6 (permalink)
ToyRolla97's Avatar
I think the old girl just needed a good, long, highway run... I drover her from Columbus to Cincinnati, and back in the same day...
MPG from Columbus to Cincinnati: 24.2
MPG from Cincinnati to Columbus: 38.7
Old 07-16-2011, 12:03 AM   #7 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1340866
iTrader Score: 7 reviews
Is one direction going up hill with a headwind & the other going downhill with a tailwind? That seems to be a huge difference for each way. I just had my best tank ever for my 94 Corolla with a 5M at 38.2 mpg. Although I've only had it on the open road a couple of times as most all of the 215k miles on her are a combination of hwy/city driving.
ROTM November 2011 Winner!
SuperchargedMR2 is online now   Reply With Quote
Old 07-16-2011, 12:17 AM   #8 (permalink)
ToyRolla97's Avatar
Well, the trip back IS technically an elevation drop overall, although not much.
That was the best tank I've had so far, as I said, I was averaging 25MPG per tank for a long time, which is what I'd expect from the 3-speed, especially with 207k on the clock.
The biggest difference is that the trip back was made at night, in cooler air (in the upper 60s), with the A/C off and just the fan running, whereas the trip down was made with the A/C on full blast in the middle of the day in the heat (mid-90s). I almost couldn't believe the numbers when I topped off my tank this morning! I ran them twice just to be sure!
I don't think that'll be a continuing trend, but it was exciting to share! I'll be monitoring the next tank to see what kind of mileage I can continue to get.
Old 07-16-2011, 03:31 PM   #9 (permalink)
Andele, andele!
speedy25's Avatar
I have an issue with the mileage calculations too. 3-4 mpg would be the difference on a highway trip.
And the trip to cincy is downhill. Water from Columbus goes to the Ohio.
-SP
Old 07-17-2011, 11:45 PM   #10 (permalink)
ToyRolla97's Avatar
-SP
I understand, believe me, and I was kind of confused by it, as well. I double checked the numbers when I got back home and topped off my tank, I had traveled 124 miles and the pump stopped at 3.204 gallons of gas... If anything, I'd say the calculation I made from the trip down may have been inaccurate, as it was the last half of the tank I used to go down, so there was a bit more guesswork involved in what the MPGs were. The trips I've made with my fiance to Elyria (via I-71 to OH-301) I usually average about 27-30 MPG, and the trips back are usually 30-32.
