1996 Starter Burned Up Today... Replacement Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2011, 10:13 PM   #1 (permalink)
View noram's Photo Gallery
My starter seized in the "on" position today. I couldn't turn the car off. Had to disconnect the negative terminal on my battery to turn it off (after smoke was billowing out of the starter).
So I found two used starters for 40$ each.
1. 1996 1.6L 1.0 Khz
2. 1997 1.6L 1.4 Khz
Can I use 2. on my 1996? Is the higher hertz number better?
Thanks,
NORAM
noram is offline   Reply With Quote
Old 07-06-2011, 10:37 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
its not hertz, its watts. KiloWatts. The more powerful start is for the 'winter' package, it will pull a little more power from the battery when starting in very cold weather, but will also be able to turn the engine faster to start easier in very cold weather. Given where you live...get the 1.4 KW starter.
Old 07-07-2011, 02:00 PM   #3 (permalink)
Hey thanks, I have a new battery and alternator so it'll be good to go.
Do i need to worry about changing any fuses for the difference in watts?
Old 07-07-2011, 07:04 PM   #4 (permalink)
Bitter's Avatar
the starter power feed wire has no fusing that I'm aware of. It might be prudent to upgrade the ground to the body/engine and the power wire to the starter/alternator. I tend to find that after many years the wiring becomes worn and new heavier gauge stuff makes a noticeable difference.
Old 07-11-2011, 03:23 PM   #5 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
Having just replaced our 96's 1.8L automatic starter last weekend, let me just give you this tip: remove the passenger side wheel and plastic splash guard under the crank pulley and belts. This lets you get to the lower starter bolt much easier with a bunch of ratchet extensions, and also gives easier access getting the starter out of the bay.
Getting those bolts started again when you put the new one on is a PITA, though. At least it was for me with the A/T, subframe, exhaust pipe, and axles all up in the way.
PatrickGSR94 is offline   Reply With Quote
Old 07-11-2011, 06:48 PM   #6 (permalink)
Bitter's Avatar
I went in from the top under the manifold.
Tags
1996, burn, corolla, starter
