yea, wait, this is misleading...first of all rule out the timing belt, and even if it was your timing belt, these engines are "non-interference" which means means the pistons will not touch the valves in the event that the belt breaks.
Now, if the water pump belt broke, which it sounds like it did, then this means potentially you could have ran the engine hot. So don't just assume its a simple fix yet. I suggest putting on a new belt, check to see that ALL the pulleys, except for the crank pulley of course, spin freely (because a seized pulley can easily cause the belt to break). Once you have checked that, and it's good, add coolant. I might go as far as saying pressure check the cooling system at this point to check for any more water leaks. If not, run it. Check to see if you notice any steam (sometimes confused by smoke) coming out the tail pipe. Check to see if you have any bubbling in the overflow tank. If you do....sorry bro, you may have a blown head gasket from it running hot.
But hopefully I'm wrong and like everyone else says it's probably fine...but jus wanted to make sure you know to check it out good in this case...Good Luck
