What the gauge is actually registering is fuel level, not fuel volume. Since the fuel tank isn't a perfectly regular shape, the level doesn't decrease consistently with fuel usage.
Think of a bottle which has a long thin neck - put it under the tap and turn the tap on so you get a constant stream of water. Notice how the level in the bottle goes up relatively slowly in the bottom of the bottle because it is wide, but as the level reaches the narrow neck it rises faster and faster (despite the same flow of water in)? This is basically the opposite of what is happening in your fuel tank. The top of the fuel tank is big and wide, so the float (and needle) will drop slowly as a change in volume only slightly decreases the level. As the level in the tank decreases, the shape of the tank changes and causes the level to drop faster, hence why the gauge drops faster in the bottom "half" of the tank.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
