Rear Hub Assembly Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2011, 07:39 PM   #1 (permalink)
View Rbuckyfuller's Photo Gallery
Exclamation Rear Hub Assembly Removal
Hi. I am trying to replace the rear hub assembly in my '95 corolla. I take off the wheel, and the manual says to take off the brake drum next. (There do not appear to be brake calipers).
But the daggon thing won't come off. I try to pull it off, and at first I just thought it was rusted on, but it wasn't. I was able to get it part the way off, but now it feels like it is being pulled back in by springs. What is going on? I'm afraid I'll pull off the brake shoes or something if I force it off. Does anyone have any suggestions?
Edit: My bad man, figured I wouldn't bother people with a whole new thread.
Rbuckyfuller is offline   Reply With Quote
Old 07-14-2011, 07:55 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Moderator- Can you move this to its own thread since it has nothing to do with front wheel bearings.
The drum doesnt come off easily because of the unworn/rusty edge of the drum. If you can get at the adjuster you can back it off, or just keep yanking until it slides off. Pull it STRAIGHT off for the easiest removal.
-SP
Old 07-14-2011, 10:26 PM   #3 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Moved
Old 07-16-2011, 03:20 AM   #4 (permalink)
Living on a Rock
kaitaiya's Avatar
Gameroom cash: $212950
View kaitaiya's Photo Gallery
you gotta back off the star adjustor for the parking break. you should be able to get to it from the access hole in the bottom of the drum backing plate with a screw driver.
解体屋 Just a gearhead in paradise...
93 JDM AE102 20V Blacktop Blacktop Wiring DIY
The Somewhat tips and trick to the install
Proper Planning and Preparation Prevents P*** Poor Performance.
kaitaiya is offline   Reply With Quote
The Following User Says Thank You to kaitaiya For This Useful Post:
Rbuckyfuller (07-19-2011)
Old 07-17-2011, 04:32 PM   #5 (permalink)
blb
View blb's Photo Gallery
Manually adjust the starwheel in a few turns, using the slot in the backing plate, then use bolts in the two holes near the center of the drum to jack the drum out. Once the drum is off, grind off the ridge at the outer edge so you don't have the same issue the next time.
blb is offline   Reply With Quote
The Following User Says Thank You to blb For This Useful Post:
