Radiator fins - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2011, 01:01 AM   #1 (permalink)
View agmgranturismo2006's Photo Gallery
Radiator fins
I have noticed recently that i am getting a coolant drop in the coolant reservoir about a half inch every trip i checked for leaks in every where there was no traces but only at the radiator itself i found coolant traces on the fins so i think the fins OR inner radiator tubes are leaking.
1st-how can i fix this problem cause i am low on budget currently and can not afford changing a radiator
2nd-can i drive with this problem and continue adding this tiny amount of radiator fluid every trip as my car never over heats and operating in the normal temperature range
3rd-is this OEM radiator aluminium or brass?
grateful for everyone who is going to help me
[SIGPIC]GRAN TURISMO the real driving
simulator
agmgranturismo2006 is offline   Reply With Quote
Old 07-15-2011, 07:06 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
1. no, cannot repair without causing more damage to the radiator
2. yes, just keep the coolant full. DO NOT use stop leak products, they will clog the cooling system and cause your car to over heat
3. Aluminum.
Old 07-15-2011, 09:44 AM   #3 (permalink)
blb
View blb's Photo Gallery
I am not normally a fan of stop leak products, but given your situation, you could try a tube of Bar's Leak Gold. You can buy this at WalMart for less than $2.00 per tube. If is a brown powder (ground ginger root among other things) sold in a small tube and it will not clog heater cores or radiators. It is made of the same ingredients that GM Coolant Suppliment Tablets are made from, and GM specifies the use of these during each coolant change for several models including the older Northstar engines. Do NOT use the Bars Leak product that looks like rubber chunks in syrup and I would also avoid the aluminum flake stop leak products as these are likely to clog a part of your cooling system.
blb is offline   Reply With Quote
Old 07-15-2011, 11:49 AM   #4 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
There are a variety of stop leak products, I'm not a fan of any of them. And really a radiator for these cars are not that expensive so imo I would change the radiator. Heck if you really need to save, consider a radiator from a u-pull-it yard. Some offer a 30 day warranty and you can get one pretty cheap, then perform a flow test on it before you install it and then, install it, add water, and pressure test it. If it's good, then drain it and add your coolant...good to go.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 07-15-2011, 07:36 PM   #5 (permalink)
Bitter's Avatar
I don't think they have Walmart in Egypt...
Old 07-15-2011, 11:19 PM   #6 (permalink)
Thanks all for your answers and i am currently checking the radiator fluid every trip
simulator
Old 07-16-2011, 03:38 PM   #7 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Save your money for a new rad. It WILL get worse. The day you find the reservoir empty you'll know for sure you have gone as far as you can safely.
Dont forget to do a flush before you install the new rad.
-SP
