Originally Posted by speedy25
First get a cleaner and follow the directions on the bottle. The cleaner is VERY good at removing scale and other crud from the coolant passages. Then use a flush and fill kit so you can BACKFLUSH the system. Many times there are collections of crud that block passages that can only come out by reversing the flow direction.
Open the drain on the radiator like the directions say but you dont have to open anything on the block. Many times these are rusted to the block and you can break them off trying to remove them.
-SP
But if you don't remove the block plug after doing that, you'll have some of the flush fluid and hose water mixture in the block. I NEVER recommend putting any type of water permanently in a cooling system other than distilled water. Water out of the hose can cause even more of the scale and corrosion that you just tried to remove with the flush.
I always recommend the following procedure:
1. Turn interior heater to full hot, drain radiator, and drain engine block.
2. Remove upper radiator hose from head, and lower hose from radiator.
3. Remove thermostat, then place thermo housing back on w/o the thermostat (finger tight bolts are fine).
4. Flush the system through the upper radiator hose and into the radiator with plain hose water until the stuff coming out the lower radiator hose runs clear.
5. Drain radiator and block again to get all the hose water out. Just remove the lower radiator hose from the radiator to drain it faster.
6. Put new thermostat in, close everything back up, and fill the radiator with a 50/50 mix of coolant and distilled water. I always use Prestone green coolant in both the Integra and Corolla, never had any issues. My current Integra radiator has at least 150K miles on it (303K miles on original engine and transmission).
7. Squeeze upper and lower hoses to expel as much air as you can, and fill with more coolant mixture to bring the level up to the base of the radiator neck.
8. Start and run the engine with the radiator cap off, heater still on full hot (no need to turn on the blower). Wait until the thermostat opens, both hoses get hot, and the radiator fans cut on. The coolant should go down a bit after this point so you'll need to add a bit more, then close it all up.
9. If the coolant in the radiator rises while the engine is running and heating up, that means there is still some air in the system. I would shut off the engine and squeeze the hoses some more until you can get that air out.
