Originally Posted by Kevinpiersonandson
I jumped the terminals but I don't even get a check engine light.
With no code you should get constantly flashing CEL. Poor connection on the TE1 and E1 while jumpering them?
The timing doesn't change with the terminals jumped - it should - and the computer is telling it to fire at nearly 25 degrees BTDC, this is what's causing the poor combustion and all the smoke. I think.
+1 on that. Standard timing with TE1 and E1 jumpered is 10 degrees BTDC, for normal gasoline that is, max 5% ethanol. Without TE1 and E1 it usually settles at 15-ish at idle.
