94 Corolla - Blower Motor has only 1 speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2011, 04:17 PM   #1 (permalink)
View jim511's Photo Gallery
1994 Corolla and the blower motor only works on low speed. No brainer, right? Somewhere along the way the high blower relay went and also the resistor block (for speeds 2 &3). Nope! replaced them both, still the same
Got to now assume it must be the switch itself. Anyone else run into this?
Thanks,
jim511 is offline   Reply With Quote
Old 07-20-2011, 04:27 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I would assume your assumption too. Resistor failure makes the low speeds not work. Having one speed proves the fan works.
It can also be a wiring problem.
-SP
Old 08-10-2011, 05:03 PM   #3 (permalink)
View Polar57's Photo Gallery
My 90 Pickup blower speeds narrowed down to slow, 2, slow, and slow. But with the temperatures here near 100, I needed high. I checked the resistors and they're all good, so it's probably the switch. To bypass the switch and get only high working, I pulled the plug from the resistors, then put a jumper across two wires. I used a piece of steel from an old wiper blade because it fits nice and snug into the plug.
Polar57 is offline   Reply With Quote
