noise when i turn my steering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2011, 01:18 AM   #1 (permalink)
View Zain's Photo Gallery
hey guys ive been hearing this noise when i turn my steering, and this time its not the old squeaking sound cos of belt
it sounds kind of dry or its rubbing against something
what could possibly be wrong with it?
Zain is offline   Reply With Quote
Old 07-22-2011, 01:28 AM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
It could be the clockspring (wiring for the horn and airbag) is dry and rubbing. Some say that a bit of talcum powder can help it. It can also be caused by the boot that the steering shaft runs through the firewall.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 07-22-2011, 01:27 PM   #3 (permalink)
how can i fix it?
Old 07-22-2011, 01:33 PM   #4 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
"Some say.... that he once used talcum powder to fix a squeaky problem. All we know is, he's called the Stig!!!"
OP if it's the steering shaft rubbing then a bit of multipurpose grease might do the trick. You'll probably have to move the steering wheel back and forth (or have someone else do it) while you try to listen under the dash and steering column area to try to pinpoint the source of the noise.
PatrickGSR94 is offline   Reply With Quote
Old 07-22-2011, 11:35 PM   #5 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
+1
before you go spreading talcum poweder around, I would pinpoint the noise. It may even be in the rack and pinion, steering shaft, or linkage somewhere.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 07-23-2011, 10:17 AM   #6 (permalink)
btw the steering is not as soft as it use to be
