Timing Belt Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2011, 08:04 AM   #1 (permalink)
View bunchy's Photo Gallery
Smile Timing Belt Replacement
Is the 2E engine (1.3 L) on a 1994 manufactured Toyota Corolla (Model EE100R-AEMDS) of interference type? at what mileage should timing belt be replaced? Does mileage depend on manufacturer of belt?
bunchy is offline   Reply With Quote
Old 07-24-2011, 07:23 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Yes, the 2E is an interference engine. The timing belt should be replaced every 80,000 to 100,000km (50,000 to 62,000 miles), regardless of which brand of belt is installed.
Old 07-24-2011, 11:20 PM   #3 (permalink)
Thanks a lot for the information. Considering that the engine is of inteference type I better go by the lower interval of 80,000 km. Thanks again
Old 07-24-2011, 11:44 PM   #4 (permalink)
Full Throttle
No problem. It's highly recommended to also change the water pump at the same time
Old 07-25-2011, 12:15 AM   #5 (permalink)
Thanks. My present odo reading is nearing 80,000 km but I noticed a sticker on timing belt case stating it was replaced at 47,856 km!! (by previous owner). I guess I can wait till I reach 127,500 km to change again and also replace the water pump at the same time.
Old 07-27-2011, 04:44 AM   #6 (permalink)
Just a final query : Is it standard practice to replace the tensioner also when replacing the timing belt
Old 07-27-2011, 05:14 AM   #7 (permalink)
Full Throttle
I did when I replaced mine. It's not an overly expensive part so I did it more as a precautionary measure than anything. You'd get away with doing it every second timing belt change, but for peace of mind you may as well get it done while everything else is off, especially considering that your engine is the interference type
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
bunchy (07-27-2011)
Tags
bunchy
