fuel tank pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2011, 03:58 PM   #1 (permalink)
View agmgranturismo2006's Photo Gallery
fuel tank pressure
when opening the fuel tank cap on my car at the petrol station to refuel it there is a burst of pressurized air comes from the tank so isnt there any way for tank ventilation i am affraid of pressure build up in the tank
[SIGPIC]GRAN TURISMO the real driving
simulator
agmgranturismo2006 is offline   Reply With Quote
Old 07-24-2011, 08:37 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I the USA there is a vapor recovery system for the fuel tank, so our tanks (when all the parts are working right) have a vacuum when opened. You'll have to get a manual from your country to see how Toyota does it in Egypt.
-SP
Old 07-25-2011, 12:27 AM   #3 (permalink)
my engine is a 2e carburator so i dont have emission contol system just i have a tiny vapour canister in the fire wall with one hose connected to the tank and the other to the air i think it must be clogged so can i just cancel it and make the hose from the tank open to the air cause i think there is another pressure relief valve inside the tank already?
simulator
Old 07-25-2011, 11:54 AM   #4 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
Interesting, I can tell you from experience, I had this problem on the 7AFE and 4AFE engines. In fact, if you search you will see some other threads with the same issue. I found the charcoal canister was stopped up causing the pressure build up and it literally burst two fuel tanks before I figured it out. It caused a seam in the tank and the tank started leaking. So make sure you don't put this issue off for long...
I would disconnect the vapor line to the canister you spoke of and drive it a little while. See if you still have the built up pressure. If not, more than likely the problem is inside that canister.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 07-25-2011, 01:47 PM   #5 (permalink)
wei
wei's Avatar
View wei's Photo Gallery
Maybe not relevant to OP, but would this cause issues at inspection for US cars?
1997 Corolla CE - Sold as of 2/2012
2009 Corolla LE
2008 Mazda B2300
wei is offline   Reply With Quote
Old 07-25-2011, 09:23 PM   #6 (permalink)
trife96's Avatar
Yes, very possible. And just want to mention, I'm not suggesting to leave it that way, but only as a way to test to see if the canister is the culprit.
