97 Corolla Brake Rotor removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2011, 04:38 PM   #1 (permalink)
View porkfriedrice's Photo Gallery
I'd like to double check that there is nothing holding the rotors on besides the caliper mounting bracket. I removed the bracket and cannot get the rotors off. I did a search on this site and found that you can use a couple of screws in the screw holes on the rotor to get it off. It mentioned the screw size, but I'd like to verify that it's correct. Anyone know the size offhand?
porkfriedrice is offline   Reply With Quote
Old 07-29-2011, 08:35 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
same size thread as the spare tire hold down in the trunk, use it to match to the correct bolts. thread two bolts into the rotor, tighten them with a ratchet. if you tighten them in and nothing happens, smack the rotor hat with a hammer and it should pop up and come off. more hitting may be needed.
be sure to clean the hub to BARE SHINY METAL so the new rotor sits flush on it.
Old 07-29-2011, 10:19 PM   #3 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
porkfriedrice...lmbo, def original
Nothing holding onto the calipers bro, they must have been on there a while...once you remove the caliper and the caliper bracket...it just a rotor. A little surface rust is holding it on maybe. Hit it with a hammer.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 07-29-2011, 11:29 PM   #4 (permalink)
The Commuter
View badquenga's Photo Gallery
Yep. If you're replacing it, just get a heavy hammer and whack it. If you're keeping it, hit the middle and bang the rust loose. It'll come off, it's just stuck.
You can watch my youtube video where I do my M3's rear brakes. Part II shows where I tug on it and it doesn't come off either. After whacking the shiznit out of it, it finally came off. Make sure you put some anti-seize on it after taking it off to prevent this in the future.
badquenga is offline   Reply With Quote
Old 07-30-2011, 12:06 AM   #5 (permalink)
Thank you all for the advice on removing the rotor. When I was trying to loosen the caliper mounting bracket bolts to get the rotor off, I got a little overzealous and broke one of the rusty bolts. I am planning on going to a dealer tomorrow to try to get a new one. Napa was no luck, and a lot of Googling hasn't turned up anything on the bracket bolts. Anyone had luck at the dealer for these bolts?
Old 07-30-2011, 01:22 AM   #6 (permalink)
The Commuter
Oops! You need some PB Blaster man. You should be putting that on everything before you take it off on such old cars. If you can't get one at the dealer, find out the size and grade and you can order one from Fastenal. My girlfriends Jeep Grand Cherokee had a Caliper bolt fall off. It's a 2001 and they don't carry it anywhere. Ordered one from Fastenal and got it within a few days. Cost $10 though...they charged like $7 to ship!
Or a junk yard...but, bring PB Blaster!
Old 07-30-2011, 08:39 AM   #7 (permalink)
Bitter's Avatar
The dealer should stock that bolt, it's used on SOO many different Toyota's and not just for caliper brackets. Well..my local dealer would have it stocked. Your dealer might be a little smaller.
Old 07-30-2011, 12:40 PM   #8 (permalink)
I did use PB blaster, but I was just too impatient. I learned my lesson. Thank you all.
Old 07-30-2011, 07:58 PM   #9 (permalink)
Sorry for the double post, but I wanted to say thanks again, especially to bitter for the tip about the spare tire hold down. I just used that to pop the rotor off. Worked like a charm. As for those bolts, I spent 20 minutes at the Toyota parts counter while the guy tried to figure out the part number for them. The diagrams are really vague. We finally decided that it was part #47710A on the diagram. Of course they had none in stock to compare to the old one, so he called a dealer further away since they had 20 in stock so they could try to compare over the phone. According to the other dealer's decription, it looks like it's the right one. So they're ordering them and I'll have them Tuesday.
Old 07-30-2011, 11:23 PM   #10 (permalink)
Bitter's Avatar
I think that part number may be the bolt that threads into the caliper slide pin....I could be wrong. You want the one with the 17mm head I think...
Ok, no it's correct I think
90119‑12040 *12-1.25PX25.8-19.5
M12x1.25 thread by 25mm long
