distributor
ok here is the problem my 96 corolla has the 4fe and it was replaced with another but my distributor was stolen some or misplaced and i bought another for this engine it will start but then die start then die i look at the part and the distributor has 1 hole for mounting (not adjustable) with a 4 wire plug now my last distributor had 2 mounting holes with a sliding mount for adjusting but i cant find that distributor with the 4 wire plug and the adjustable base. the 95 and under comes with the 6 wire plug and a 2 wire plug with the adjustable (not for the engine with the cam sensor) my car has the cam sensor which needs the 4 wire plug i CONNOT find the distributor that i need. all the ones for the 96 corolla 4afe come with the 4 wire plug but with 1 mounting hole which is throwing my timing off! please some one help me o and my timing is right on. cam gear hole lines up with the notch on the head and the notch on the pully is in line with the 0 mark this is correct right?
