Hi,
So I bought a Toyota Corolla '93 (manual) from a private owner a few weeks back. The engine was been swapped, and I'm pretty sure the transmission has been also (I can get back to you on that one. I would need to call the previous owner). The body has 214,000 miles and the engine has 98,000 miles.
I started to notice I couldn't shift from 1st to 2nd gear a few weeks back. Here are the details:
- It's really hard to shift into 1st from neutral when I'm decelerating. In fact, it's almost impossible. It feels like it's catching on something, and not until I get maybe below 10mph will it let me shift into 1st.
- Shifting into 2nd is a little less rough, but it's doable. Again, It's like the gears aren't catching right and the stick doesn't move from one gear to another smoothly, more like in "steps"
- None of these problems are an issue when the car is stationary.
Today, to work I was good enough to screw up the 3rd gear. I was spacing out and I tried getting into 3rd
while letting go of the clutch. I heard the gears grind a little bit and immediately stepped back onto the clutch.
Now the 3rd gear is acting the same as the 2nd.
I've talked to a few people who know about cars but not too much about manuals. This is my 1st ever manual so I might have done a little damage to it while learning, even though I tried to be careful.
All they've said is the synchro needs replacement, and there's no way I'm going to spend ~$1000 (from what I hear, the part itself is relatively cheap but the service is outrageous) on a car that I don't plan to keep for more than 1~2 years. I also don't trust any mechanics in town either, which blows. Hence I'm here asking for someone's help.
I've read some other posts and other forums, and by the sounds of it this could be my answer. Let me know what you guys think:
"Well you can get it in gear with the engine shut down right? So that tells me the clutch isnt disengaging. The cable could still be at fault. If you have the adjuster all the way up and you still cant really disengage the clutch the cable might be stretched. That is a cheap part and easy to replace. It could also be the fork is bent or broken most likely not though. Try moving the clutch fork lever. Does it move excessively? It could have poped off the pivot point or the TB clips could have come off."
If there's anything else it could be, please let me know. Also, even though I want to take care of my car and I really like tinkering, I'm no gear head. This is my 2nd car ever and I've never had the opportunity to take cars apart and work on them. I can definitely get a service manual and I can get a hold of the necessary tools, but I'd really appreciate it if your answers are more than just "oh, it's 'x' part. switch it".
Also, I've already checked and refilled the transmission fluid.
Thanks in advance for the patience and help.
