Just bought a geo prizm... got a nasty vibration at around 1000 rpms - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2011, 08:48 PM   #1 (permalink)
View BladeX10's Photo Gallery
Anyone know what could be the problem? car is running good at idle now but when its at 1000 rpms its got a vibration that shakes the whole car as its rising and coming down in rpms, its always around 1k either way. Also when the ac is on, a small vibration comes at idle.
Let me know what you think. Car is a 1.6 automatic with 159k
BladeX10 is offline   Reply With Quote
Old 08-11-2011, 07:32 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
replace all 4 mounts.
Bitter is online now   Reply With Quote
Old 08-11-2011, 09:34 AM   #3 (permalink)
Do you know their locations? I see 1 on the passenger side so far. Doesnt looked damaged from what i can see.
Old 08-11-2011, 10:17 AM   #4 (permalink)
View mvftw's Photo Gallery
Also check your harmonic balancer...
mvftw is online now   Reply With Quote
Old 08-12-2011, 12:23 PM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
yeah Thats what i thought when I was replacing my trans. Later I removed the rear mount and poked around and found it was separated from the metal shell.
Common wear part for Toyota. The advice for you is good.
-SP
Old 08-12-2011, 05:06 PM   #6 (permalink)
Wheres the transmission mount located? Im pretty sure thats where the vibration is coming from
Old 08-12-2011, 10:59 PM   #7 (permalink)
View ViewlessSquid's Photo Gallery
One is behind motor by flex pipe. engine mount is on the passenger side, torque mount is in the front where the crossmember is, and the transmission mount is under the airbox(must take out).
ViewlessSquid is offline   Reply With Quote
Old 08-13-2011, 03:05 AM   #8 (permalink)
Ill check them all out. Have a feeling itll either be the transmission mount or the one by the flex pipe
Old 08-13-2011, 12:59 PM   #9 (permalink)
Just put a jack underneath the oil pan and the vibration pretty much went away.. So now i know its a motor mount. Still trying to pinpoint which one or 2 or 3 failed
Old 08-13-2011, 02:43 PM   #10 (permalink)
Bitter's Avatar
replace all 4. trans and engine and front will make the biggest difference. if all are worn and you replace one, it will be doing too much work and wear out very fast.
Old 08-14-2011, 09:03 AM   #11 (permalink)
Andele, andele!
speedy25's Avatar
You wont be able to tell without removing them.
I posted a DIY for the rear. Its the hardest one to get at. The others are fairly simple.
Plan on all four, but I can be fairly certain that the front one is wasted and the other three are separated.
-SP
