1994 'rolla turn/hazard flasher problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2011, 05:58 AM   #1 (permalink)
View tiredofwrenchin's Photo Gallery
one of my son's friends wrecked the front end of his '94
corolla and i rebuilt it for him....i've done quite a few
and they are not to bad to do if the frame rail/horns aren't
bent any....there is a main wiring harness that is attached
to the radiator support that you have to be careful of but
it was undamaged....that being said,my issue is i replaced
the headlights,marker lights and turn signal lights with
brand spankin new'uns......the car looks great but there is
only one issue i'm not sure how to tackle.....the turn
signals flash fast (like there is a bulb out,but there isn't
any out),and the hazards flash normally....from what alldata
tells me/and from what i've known forever,they utilize the
same flasher....how can this be?.....of course i don't know
if it was doing it like that before,but i think its
something i'd like to figure out for future cars....any
ideas?....and yes i replaced ALL bulbs with new AGAIN....i
had NO wiring loose upon rebuilding the front end...no
grounds,no broken wires....nuttin...built aplenty of these
but NEVER had an issue like this before....any help is
appreciated....steve
tiredofwrenchin is offline   Reply With Quote
Old 08-17-2011, 07:18 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
bend the bulb contacts in the sockets up and out to make better contact with the bulbs. FRONT AND REAR.
Bitter is online now   Reply With Quote
Old 08-17-2011, 07:32 AM   #3 (permalink)
View bior0003's Photo Gallery
You could try some contact greese on the bulbs, I think they sell it at O'Ryleys in ketchup packet size for less than 5 bucks.
bior0003 is offline   Reply With Quote
Old 08-17-2011, 08:49 AM   #4 (permalink)
not sure of the fix here.....
if the hazards work properly but the turn signals don't,why would connections and or dielectric silicone do anything different?....just curious....
Old 08-17-2011, 07:06 PM   #5 (permalink)
Bitter's Avatar
Because hazard ignores the resistance of the circuit where as turn has outage detection. A high resistance can still light the bulb AND flash fast for an out bulb.
I had this happen to me before.
Old 08-17-2011, 07:21 PM   #6 (permalink)
View Halitech's Photo Gallery
I'm not sure and I'm trying to remember for sure but this sounds close to what happened with my g/fs sons car except he also lost the dash lights. All the fuses, bulbs and contacts were fine and we ended up replacing the turn signal assembly to fix his issue. Be careful if you swap that out though as when I did his, I didn't notice it has cruise and installed a part that didn't have the cruise control on it
Halitech is offline   Reply With Quote
