Brake problems after replacing rear shocks.
Alright, so I replaced my rear shocks and in the process broke my left rear brake line (and sawed off my sway bar links). I also had to replace my right side rear wheel cylinder because I stripped the drain bolt and the brake line. So I have new brake lines on the rear (just the steel part) and a new wheel cylinder on the right rear. I used double flared metric lines but they only had longer than what I needed. So had to make a couple loops before going into the shock bracket. The clearance is fine and everything I am just wondering if I am getting air trapped in the loops.
By the way, I have a 93 corolla. No ABS.
I am bleeding the brakes per manual spec and not getting any pressure back. I have the reservoir lid off. I started at the right rear, pumped the foot pedal for a while, held the brake, break the bleed screw and close bleed screw before releasing the brake pedal. I then did this to front left, then rear left, then front right in that order. I bled until only fluid came out and I still have no brake pressure.
One odd thing- I didn't seem to notice the brake fluid level dropping very much in the reservoir except for when I filled it initially. I don't have to have the car turned on while doing this do I? Am I missing something?
