Hood latch adjustment? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2011, 09:10 PM   #1 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143200
View Piloter's Photo Gallery
Anybody know how this is supposed to work? Long story short, I have to half-sit on my hood to get it to latch now. The Chilton manual doesn't go into it and I'd just as soon not go loosening all those untouched 15-year-old bolts without a more precise idea of what the hell I'm doing.
WIP AE102.
Piloter is offline   Reply With Quote
Old 08-19-2011, 03:31 PM   #2 (permalink)
View bior0003's Photo Gallery
On my 95 dx there are rubber stoppers that screw up and down to adjust how much the hood will pop up and down (located on the left and right side in front of the radiator). If these got moved too high up, it may be holding the hood up too high. Might be a quick thing to check
bior0003 is offline   Reply With Quote
Old 08-19-2011, 06:40 PM   #3 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
I don't think that the hood latch has any adjustment in the screws (I just removed mine). But yeah, check the hood bump stops.
gold94corolla is offline   Reply With Quote
Old 08-19-2011, 06:51 PM   #4 (permalink)
Dirty Dude's Avatar
Gameroom cash: $121500
View Dirty Dude's Photo Gallery
Only adjust the rubber pads enough for the hood to latch properly. If they are too loose, it is possible for the hood to rattle.
1994 Pickup base model and a couple Mustangs.
Dirty Dude is offline   Reply With Quote
Old 08-19-2011, 07:44 PM   #5 (permalink)
TIEyota fighter ace
Piloter's Avatar
The latch has been torqued a little too far down between the deer incident and a small accident to catch the loop properly now. I may just have to suck it up and start trying (carefully) to twist/bend up the crossmember that the latch bolts onto. The bump stops are down all the way, making the hood line below the actual fender line, but it still requires that extra force to get closed. I'll post back with what I figure out.
WIP AE102.
Old 08-20-2011, 08:04 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
While toyota's assembly at the factory is good enough that they dont have to put adjustment holes, you may have to. Its not a sin to oval the holes to get your hood to latch correctly especially since the car has been damaged.
-SP
Old 08-20-2011, 01:35 PM   #7 (permalink)
Yeah, if you've gotten into an accident, then you should drill some new holes.
