Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2011, 01:58 PM   #1 (permalink)
View JakeGa's Photo Gallery
Help
Ok, we got the new (used) exhaust manifold back on and tightened down. Now, the engine will not turn over. It make a (as in one) click but will not start. The car was running and starting fine when we took the manifold off. Any ideas. Could we have damaged the O2 sensor that is on the pipe. I had to hose the bolts down with Kroil to get them to break loose and some may have dripped onto the O2 sensor.
JakeGa is offline   Reply With Quote
Old 08-21-2011, 02:49 PM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $255850
View Tech1984's Photo Gallery
Jake try rapid repeated attempts with the key. I mean as fast as you can count. It may catch and that would prove to be starter contacts. Very common.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 08-21-2011, 03:03 PM   #3 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
maybe the battery got zapped or loose?
gold94corolla is offline   Reply With Quote
Old 08-21-2011, 08:03 PM   #4 (permalink)
Thanks guys,
The wing nut on one battery terminal was loose enough to prevent it from cranking. Two turns to tighten it and she fired right up. All that work fighting the nuts off the manifold and then I spent three hours trying to find that simple little issue. Makes ya feel kinda stupid....................
Old 08-21-2011, 10:09 PM   #5 (permalink)
I thought the battery was loose lol... I know how much work goes into the headers and figured it was a simple matter!
