Power steering leak detection - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2011, 10:14 PM   #1 (permalink)
View kendrick's Photo Gallery
I have an intermitant leak from my power stearing system. It has coated the firewall and hoses in the back of my engine compartment. I cant figure out which line broke and needs replacing. any suggestions on how to isolate them so the leaky one can be replaced?
kendrick is offline   Reply With Quote
Old 08-24-2011, 08:58 AM   #2 (permalink)
View mvftw's Photo Gallery
Most likey your high pressure hose...$40 part. You can use Lucas Power Steering fluid first, it can't hurt...
mvftw is online now   Reply With Quote
Old 08-24-2011, 06:53 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
clean it all dry, have a friend start the car and turn the wheel lock to lock while you look. It's not rocket science.
Bitter is online now   Reply With Quote
Old 08-26-2011, 05:56 AM   #4 (permalink)
View bajaclam's Photo Gallery
My car (94 Prizm) is slowly being driven into the ground (I live down 20 miles of BAD road), so when I had a power steering leak, I looked at what a pain it is to replace the hose, and just cut the belt.
No power steering for the last 20,000 miles, and I'm really used to it now.
bajaclam is offline   Reply With Quote
Old 08-26-2011, 09:34 PM   #5 (permalink)
Bad Black 96
badcompany87's Avatar
View badcompany87's Photo Gallery
I agree with mvftw, I had a power steering leake and it was the pressure hose. In my case it wasn't a tear in the actual hose, there's a brass fitting on the end of the pipe near the pump, and it was leaking from there. It's not an expensive part though, hope this helps.
badcompany87 is offline   Reply With Quote
Old 08-27-2011, 09:31 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
My hose seeps at the rubber/metal joint. Not enough to do anything about until it makes a real mess.
-SP
