'97 Corolla brake lights stay on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2011, 06:13 AM   #1 (permalink)
View Chris48's Photo Gallery
Noticed yesterday that my brake lights were staying on, had to pull the fuse to turn them off. I also found this on the floor under the brake pedal.
I'm guessing it's some type of stopper ??? Cause of the problem???
Are they readily available and easy to replace?
Chris48 is offline   Reply With Quote
Old 08-27-2011, 09:27 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Crawl under the dash and find out what happened. Usually the brake light stays on when the switch comes loose. I cant tell what it is in your pic.
-SP
Old 08-27-2011, 10:42 AM   #3 (permalink)
Well I got it fixed.
I took the pieces to Toyota and the parts guy immediately knew what it was - it's called a brake light switch "cushion", P/N 90541-06036 - cost was $1.93 out the door.
After removing the lower section of the dashboard, the front seat and, playing contortionist for an hour and a lot of I finally got it in, but... at 6'5" and 263 lbs it wasn't an easy task.
Old 08-27-2011, 12:41 PM   #4 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
So you fixed the problem now?
gold94corolla is offline   Reply With Quote
Old 08-27-2011, 02:08 PM   #5 (permalink)
Yes sir, fixed.
The plunger on the brake light switch rests against the "cushion" keeping the switch in the off position. Without the cushion in place, the plunger protrudes into the mounting hole for the "cushion" allowing the switches contacts to close, thus keeping the brake lights on.
