1994 corolla t-belt.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2011, 04:33 AM   #1 (permalink)
View carpetguy00's Photo Gallery
I picked up a 94 rolla with 213k on it a couple months ago. tuned up, changed the oil. clutch recently replaced also. im not sure if this car has ever had the timing belt changed. the last owner i knew, and she wasnt great at maintenance, when i bought it I had to put 2 qts of oil in it to bring it up on the stick... my friend has put 3000 miles on it, with the ac running constantly, and the oil still looks nearly new on the stick. it doesnt miss but the engine or muffler is kinda loud. runs well, zippy. so im hoping the engine is going to last a few years.
It is a 1.6, not sure which motor is in it, so im not sure if the timing belt breaking will screw up the engine (no worry in my camry) This is my main concern!..... it is a 5 speed, base model. Advice is appreciated......
97 Camry LE 5SFE 135k
94 Corolla 1.6 @ 215K
97 F150 xlt v6 120k
92 Accord 4cyl 127k (totalled 8.4.11 by semi)
carpetguy00 is offline   Reply With Quote
Old 08-28-2011, 07:14 AM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
The 1.6L 4A-FE is a non-interference engine, so if the timing belt snaps it won't cause any engine damage. The engine number is stamped vertically into the block, to the right of the exhaust manifold. Since you're not sure if the belt has ever been changed, I'd definitely replace it, along with the tensioner and water pump. There's a great write-up about the process here: DIY Timing belt and water pump replacement Corolla 93-97
Old 08-28-2011, 08:47 AM   #3 (permalink)
View bior0003's Photo Gallery
The engine wont be damaged if it breaks, but you will be stranded/need a tow.
When a timming belt is done at a dealership I think they are supposed to mark it with a sticker on the timming belt case. Might be worth a look.
bior0003 is offline   Reply With Quote
Old 08-28-2011, 11:43 AM   #4 (permalink)
Innovate or Die
MirrorEyes's Avatar
Gameroom cash: $152700
View MirrorEyes's Photo Gallery
Yeah both my belts stickers are on my valve cap, but because I painted it I moved them down to the side, near the manifolds.
Checkout my CarDomain page.
MirrorEyes is offline   Reply With Quote
