timing belt problem :[ - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2011, 12:16 PM   #1 (permalink)
View xp0undcak3x's Photo Gallery
hi guys. i got a 7afe 1.8L corolla. my serpentine belt snapped to pieces not too long ago. so i replaced the belt but then i noticed it was wobbling a good amount so i bought a harmonic balancer / crank pulley but when i pulled into the shop my car died. tried starting it and it wouldnt start. so i checked the timing belt and its done. now i wanna kno if that 1.8 is an interference or non interference motor cause im scared i messed up my valves :[ im hoping i can just do a timing belt water pump job and my car will be good again.
any advice or knowledge would be so much help.
thank you for your time.
xp0undcak3x is offline   Reply With Quote
Old 08-30-2011, 08:38 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
NOT interference. Get to work!
You also could have found this using a search. Its posted MANY times.
-SP
Old 08-31-2011, 11:06 AM   #3 (permalink)
oh.. thanks for your time. i did search it but i only found it for the 1.6 motor. i just wanted to make sure the 1.6 and 1.8 were both the same.
