Gas Milesage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2011, 01:09 PM   #1 (permalink)
View whitejl28's Photo Gallery
Gas Milesage
Hey guys,
I’m new here
just bought a Corolla
What kinda of gas mileage are you guys getting with your Corolla,
I have 94k miles on mine now and I believe I need to perform a TUNE UP on it very soon
on this current tank From Full to 1/2 Tank so far total Miles on this tank is 191 miles
When i drove it to Atlanta two weeks ago I only was getting 320-340 Miles to a tank of gas....
Is this NORMAL
whitejl28 is offline   Reply With Quote
Old 08-30-2011, 07:31 PM   #2 (permalink)
Dirty Dude's Avatar
Gameroom cash: $121500
View Dirty Dude's Photo Gallery
If you want to know the actual fuel economy,
1. Fill the tank.
2. Set the trip.
3. Drive through at least half a tank.
4. Fill again.
5. Note miles on trip meter.
6. Divide miles by the gallons it took to fill the tank.
7. ?????
8. Profit.
You can't figure fuel economy by going off the gauge.
1994 Pickup base model and a couple Mustangs.
Dirty Dude is offline   Reply With Quote
Old 08-30-2011, 08:31 PM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I have yet to see a linear accurate fuel gauge!
When you fill up your numbers should be in the 30-35 range.
-SP
Old 08-30-2011, 09:15 PM   #4 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
320 miles is what I would get on a summer tank, sounds good.
gold94corolla is offline   Reply With Quote
Old 08-30-2011, 09:51 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $614831
View Zembonez's Photo Gallery
Check the actual mileage and get back with us.
Zembonez is offline   Reply With Quote
Old 08-31-2011, 06:26 AM   #6 (permalink)
Ill check it out,
I dont think my fuel gauge reads correctly either but i could be wrong
Old 08-31-2011, 07:35 AM   #7 (permalink)
Innovate or Die
MirrorEyes's Avatar
Gameroom cash: $152700
View MirrorEyes's Photo Gallery
I get about 540 km, which I think is like... 335 Miles? ish.
Checkout my CarDomain page.
MirrorEyes is offline   Reply With Quote
Old 08-31-2011, 08:15 AM   #8 (permalink)
Then i guess im getting just about the same as you all are
I figured i was getting poor gas mileage
Old 03-27-2012, 10:14 PM   #9 (permalink)
View msrdude's Photo Gallery
The needle for the fuel goes up and down whenever you press on/off the gas, and make those curvey roads. I hate when the needle does that.
I get about 340 miles on a tank of gas. I kept filling up my car when i hit the halfway line, and until i hit the 13 gallon mark. Pretty good when my car has 143500 miles and i never replaced the o2 sensor. Actually my mpg went up after I replaced the right front motor mount; not only did my car stop vibrating when driving and at idle, but i got at least 5 more mpg.
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
Old 03-27-2012, 10:26 PM   #10 (permalink)
Gameroom cash: $110300
View fj62's Photo Gallery
-SP
I wish my 1.6 3 speed auto got 30 to 35. My window sticker which I still have says 26 city and 32 highway. With the gas that is being sold today I get 24.5 to 25 mpg consistently in city driving.
Dennis
2009 Highlander Hybrid, 2007 Camry, 1995 Corolla
Previous owned
1985 Camry, 1989 Land Cruiser, 1989 Corolla All-Trac wagon
fj62 is offline   Reply With Quote
Old 03-27-2012, 11:26 PM   #11 (permalink)
Gameroom cash: $127900
View Bstylz's Photo Gallery
a full tank i do around 250 mpg
1.6 3spd auto
Bstylz is offline   Reply With Quote
Old 03-28-2012, 06:49 AM   #12 (permalink)
tylan71's Avatar
View tylan71's Photo Gallery
Make sure your thermostat is working! I have kept a fuel log since the first fill-up of my 1.6 L 3 spd purchased used in 2005. I did a full tune up (plugs, wires, rotor, cap, timing belt, water pump, front O2 sensor, transmission fluid, switched to synthetic oil, air filter, cleaned the throttle body, coolant change) and have averaged 26-27 mpg since that time. After realizing that I may have a faulty thermostat (6 years later), I changed it and since then I have been averaging 30-31 mpg with no change in driving habits. My .02
tylan71 is offline   Reply With Quote
Old 03-28-2012, 07:53 AM   #13 (permalink)
View Mawtin's Photo Gallery
Auto or manual?
Mawtin is offline   Reply With Quote
Old 03-29-2012, 02:18 AM   #14 (permalink)
Super Procrastinator
modernage's Avatar
View modernage's Photo Gallery
I don't trust my gas gauge so I just drive around until i reach the 250-260 mark and then fill it up. Usually just takes 7.5-8.9 gallons to fill it up all the way. I average around 29-30 but after changing my oil just a few days ago I averaged 32 mpg.
modernage is offline   Reply With Quote
Old 03-30-2012, 02:06 AM   #15 (permalink)
h0yitsdom's Avatar
View h0yitsdom's Photo Gallery
96 1.8 5spd
3/21/2012 Odometer 132985 8.28gal put in
3/25/2012 Odometer 133185 6.71gal put in 29.80mpg
i would say i normally get right around 31mpg. That last tank i was doing quite a bit of 100mph stretches :|
i get 31mpg normally with a mix between some freeway and a short 10 minute drive to work and back. i drive around 80-85 on the freeway
h0yitsdom is offline   Reply With Quote
