96 AE101 Ignition Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2011, 03:53 PM   #1 (permalink)
View mcjcarey's Photo Gallery
Australia 96 AE101 Ignition Problems
Hey,
I have a 96 corolla which has never had even the slightest issue but for the last couple of days I have been having dramas trying to turn my key. I've been reading up a bit on it and last night I managed to get it turned to accessories (which doesn't normally happen). I popped the column out while the car was on accessories but I'm not really sure what Im looking for. The steering lock doesn't seem to be a factor, and if I wrench the wheel around I can get the wheel to lock and then unlock without using the key. Everything Ive read on the net gives tips regarding the ignition once its in accessories but it was pure luck I even got it to accessories in the first place... Am I looking at having to replace the ignition barrel or could it be something to do with the steering lock... Any tips?
mcjcarey is offline   Reply With Quote
Old 08-31-2011, 06:26 PM   #2 (permalink)
View 96coroll's Photo Gallery
I don't know if this is a factor. But could it be that your key has been wearing out??
96coroll is offline   Reply With Quote
Old 08-31-2011, 07:04 PM   #3 (permalink)
Australia
Yeah I thought of that.. The spare key doesn't work either though.. I managed to get my hands on a new barrel and key (advantages of family members working for Toyota) so hopefully once installed it will be right.. I'm just worried that if it's not the issue I'll be back to square one.. Only one way to find out though :-)
Old 09-01-2011, 11:15 AM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Lubrication does wonders for those kind of problems. I use lock ease. Ypou probably have some other brand of molybdenum-disulfide style that will lube and free things up.
Usually the column key is last to have problems since its out of the weather.
-SP
Old 09-01-2011, 07:26 PM   #5 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
I had this issue a few times. When replacing the key didn't work, I found that it was the actual shifter lever. Needs to be fully engaged in park for the key to be removed, no? It was a while back and I forget how I fixed it, but perhaps look at the shifter.
gold94corolla is offline   Reply With Quote
Tags
1996, corolla, ignition lock
