1993 Corolla LE stalls, help please! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2011, 07:17 PM   #1 (permalink)
View Streetmagus's Photo Gallery
Hi guys, I am having an issue with my Corolla. The car starts up fine and idles fine when cold, but once it gets to normal operating temperature, the car stalls in gear. It can idle, sort of rough, but as soon as I rev the car it will stumble and stall. After it stalls, it may take a few tries to re-start, sometimes it won't even re-start until cooled down.
I did a paper clip on diagnostics plug and got check engine light blink code pointing to 31.
According to these forums, this means MAP sensor error. I assume short circuit/open circuit issue.
I went ahead and replaced the sensor with 3 dffferent used parts, the code still remains and the car still suffers from the symptoms. Do I need to reset the code? What can the issue be?
I have already replaced the distributor cap and rotor, new plug wires and spark plugs.
Fluid levels are all normal.
Streetmagus is offline   Reply With Quote
Old 09-15-2011, 05:28 AM   #2 (permalink)
Nick
Gameroom cash: $156400
View TheNightWolf's Photo Gallery
02 Sensor is the only thing I can think of...
My Cougar was doing that for a while, and I had 2 bad mixture o2 sensors.
-1994 Toyota Corolla-Ksport Coilovers, custom exhaust, Weapon R intake with Ram Air Kit
TheNightWolf is offline   Reply With Quote
Old 09-21-2011, 03:56 AM   #3 (permalink)
Replaced the ignition coil (was part of the distributor) and it fixed my problem. I still have the error code for MAP sensor, but the car runs fine now.
