Valve cover tube grommets leaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2011, 09:24 AM   #1 (permalink)
View blacktoyo's Photo Gallery
I replaced the valve cover gasket and grommets, and I still have oil leaking into the tube of cylinder #1. The spark plug is still covered with some oil. Please advise. Thanks.
blacktoyo is offline   Reply With Quote
Old 09-13-2011, 11:59 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
You probably damaged the lip of the seal when you reinstalled the cover. A coating of oil on the tube and the seal will help keep that from happening. SOMETIMES you can remove the cover straighten out the lip and reinstall without leakage, but usually the damage is done and you will need a new one.
-SP
Tags
cover, leak, tube grommets, valve
