Originally Posted by JohnHarlin
I've got a 1993 Toyota Corolla automatic.The only way I have been able to drive lately is with a screw driver because when I put the car in Park it gets stuck there and won't start. I can't even get the car key out of the ignition because of it. I then use the screw driver to poke the override button so I can shift to neutral and start the car. But I can't do that forever.
How can I fix this problem. Should I disassemble the gear panel, the one between the two front seats and see if something is broken. But I don't even know how to open that up.
Maybe its the lockout?
If they had them in the 1993, I have no idea, but that could be gone bad.
So even when you press the brake, its not letting you shift at all.
It shifts all the others fine?
Do you get a click or a noise when you press the brake in park, like in my Cougar, I could press the brake and I'd get a thump out of the transmission hump and that was the lockout unlocking.
