1 or 2 Camshaft seals during TB change? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2011, 03:48 PM   #1 (permalink)
View Woz2000's Photo Gallery
Read through the guide and most of the timing belt threads here. Still not too sure. Is there only one camshaft seal that needs replacing? From what I can gather, the second camshaft is driven internally? Is that correct?
In the process of ordering the TB, tensioner, tensioner spring, water pump w/housing, o-ring, crankshaft seal and camshaft seal...
Also need a short hose for the water pump to elbow, anything else I need?
Thanks!
Woz2000 is offline   Reply With Quote
Old 09-22-2011, 04:47 PM   #2 (permalink)
Dirty Dude's Avatar
Gameroom cash: $121500
View Dirty Dude's Photo Gallery
Isn't there another seal at the distributor end?
1994 Pickup base model and a couple Mustangs.
Dirty Dude is offline   Reply With Quote
Old 09-22-2011, 05:27 PM   #3 (permalink)
I think I've found the answer, there is only 1 seal behind the pulley, the second camshaft is driven internally.
The camshaft should be staying inside the head on the distributor end, so there is no seal there.
http://aarc.epnet.com/autoapp/9307to.../9301Yg07L.gif
Old 09-23-2011, 11:24 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
You may find that the valve cover gasket/seals need replacing too. They are typically hard as a rock by now if they havent been replaced previously.
-SP
Old 09-23-2011, 11:34 PM   #5 (permalink)
I agree the valve cover seals are probably shot, but since those are easily done, I'll wait to see what they look like and if needed to replace them after.
-SP
