so i had a thread earlier about a squeal, that i fixed for the most part by tightening up the alternator belt..
it was back a little bit so went to tighten it some more but the adjustment bolt snapped in half !
does this bolt go into the engine block ?
if i do succeed in removing the old one, would i be able to install the new one without removing the alternator ??
thanks in advance!!
also is it possible for the alternator belt to be tight without the adjustment belt? (e.g if it was at the right tightness when the lock/pivot bolt were tightened?)
or no adjustment bolt means 100% no tension?
