what sensors are these? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2011, 04:19 PM   #1 (permalink)
Gameroom cash: $117700
View newtoyota's Photo Gallery
http://imageshack.us/photo/my-images...925170709.jpg/
the one i am most concerned about.... what sensor is that?
http://imageshack.us/photo/my-images...925170717.jpg/
AC switch ? does it affect anything else?
http://imageshack.us/photo/my-images...925170808.jpg/
comes out the bottom of the brake resevour but not connected to anything.
sorry about the bad pictures.
newtoyota is offline   Reply With Quote
Old 09-26-2011, 12:29 AM   #2 (permalink)
View alambre's Photo Gallery
Hi, I believed the first one is the oil level sensor, you can confirm this by disconnecting this socket and try turning ON your ignition if your oil indicator in the gauge will not lit. The other one is the brake fluid level sensor, disconnecting this will lit your indicator at the gauge permanently.
alambre is offline   Reply With Quote
Old 09-26-2011, 08:25 PM   #3 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
1st - Oil pressure sending unit. - If the oil pressure is too low, will cause the oil light to come on in the cluster.
2nd - Should be the a/c clutch wiring. Engages the a/c compressor.
3rd - Brake fluid light. If the level is low will put on the ebrake/brake fluid level low light. (shares one light) If its on and the ebrake is not engaged, then check the fluid.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 09-26-2011, 08:58 PM   #4 (permalink)
thanks for the info but for the brake fluid connector... mine's not connected to anything it's just lying there.... where and what is it supposed to connect to?
