Check prices via rockauto.com , that's about the cheapest you're going to get and still wind up with quality parts. From the point of view of keeping the alignment sane, you might be able to do the two rears and then the two fronts later. End links and bushings are dependent on what trim level of Corolla you have...this came up a while ago but I think only the DX and LE had front and rear swaybars stock, other trim levels may have had a front bar as an option, not sure right now and don't have the time to chase it down.
Have you done the rebound test? Put your foot on the bumper at one corner at a time, press down hard, let go, see how long the car takes to stop moving? Generally it should stop after the first bounce back up, maybe another wiggle. If it keeps pogoing noticably, yeah, your suspension's shot.
Another possibility, if the rears have the rubber-like upper mount that the fronts do (look on your strut towers), is that that could be shot/inverted/torn back there and causing the issues.
A note regarding shop rate for replacing the rear shocks and struts...there is a book out there that has an insane labor rate for the rear job, something like $900. This book is hilariously wrong and if anybody quotes you that much for it, especially if you're bringing in your own parts, laugh in their face and find another shop.
WIP AE102.
