'93 Corolla with some oil leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2011, 12:48 PM   #1 (permalink)
View armyjunk's Photo Gallery
Hello everyone, I have a 93 Corolla that has a oil leak in the timing belt end of the engine, it might be the camshaft seal but i'm not sure. What i am looking for are other ideas on where it might be. Valve cover looks dry. Its a pretty big leak, a quart every 1000 or 1500 miles on the ground. At this point I have the belts off and the plastic covers. Thanks for any info or ideas..before I put on new stuff I'd like to think I fixed all leaks....
armyjunk is offline   Reply With Quote
Old 10-04-2011, 01:56 PM   #2 (permalink)
View Woz2000's Photo Gallery
Crank seal or Camshaft seal.
Woz2000 is offline   Reply With Quote
Old 10-05-2011, 11:16 AM   #3 (permalink)
Thanks Woz
Both the cam and crank seals are hard as rocks, so I'm replacing both. The cam has a slight groove in it so I will just have to see how that works out. The crankshaft has a repair sleeve on it, any idea if a stardard crankshaft oil seal will work over the old sleeve? Thanks again
Old 10-05-2011, 11:35 AM   #4 (permalink)
Sorry, no idea. Never worked on this engine before.
Thanks Woz
Old 10-05-2011, 12:11 PM   #5 (permalink)
Thanks again
Old 10-05-2011, 12:13 PM   #6 (permalink)
YOGI.CR's Avatar
View YOGI.CR's Photo Gallery
Share a picture.
YOGI.CR is offline   Reply With Quote
Old 10-05-2011, 05:11 PM   #7 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
The sleeve is thin enough that the standard part works, BUT It shouldnt be leaking!! If you cannot remove the groove from the cam surface with a very fine emery paper, install the seal slightly inboard or outboard so the seal lips miss the groove.
Your major leakage is the crank seal, but you may have other things leaking too.
-SP
Old 10-06-2011, 07:29 PM   #8 (permalink)
thanks speedy, its back together and we will see how it does.....
Old 11-03-2011, 11:16 AM   #9 (permalink)
a month later and its dry as a bone, thanks everyone for the advice.
