» Site Navigation
» Buyers Guide
» Network Links
10-05-2011, 08:24 AM
#1 (permalink )
Will 18x7.0 4x100 Rims Fit my 95 Prizm?
I found a chart that says that the stock size is.
Geo Prizm 1990-1996 18x7.5 4x100
Will VW wheels fit ok?
Volkswagen Jetta I 1981-1984 18x7.0 4x100
Thanks
10-05-2011, 09:11 AM
#2 (permalink )
on full afterburner
What's the offset?
10-05-2011, 09:24 AM
#3 (permalink )
Originally Posted by
PhatRoyale
What's the offset?
They didn't list the offset, but it looks like they should be either 43 or 45mm
Will both of those work?
10-05-2011, 09:30 AM
#4 (permalink )
on full afterburner
If that's the offset then those wheels should fit. You might have to roll your fenders though.
10-05-2011, 10:33 AM
#5 (permalink )
Automotive Lighting Guru
The stock wheel size is 14, not 18 lol. 18s will be rather huge on a stock Prizm (no body kit). I would not recommend it. The stock offset is 40.
10-05-2011, 12:15 PM
#6 (permalink )
gold94corolla
I don't know much about wheel sizes other than bolt patterns.
One chart I found shows the prizm as:
Which I take as 7.5" wide x 18mm offset. Correct me if I'm wrong here.
These are 14" rims
Also, if the width is a little different, can I still use 175 65 14 size tires?
10-05-2011, 12:29 PM
#7 (permalink )
no, the 18 is the rim diameter. Offset is usually at the end with an "ET"
10-05-2011, 12:47 PM
#8 (permalink )
I took another look at that chart, and it says up at the top max wheel size. Sorry, I misread it the first time.
I did find this here.
http://lugpattern.net/Volkswagen_Bolt_Patterns.htm
MODEL YEAR O.E. WHEEL SIZE LUG PATTERN STUD SIZE HUB/CENTER BORE OFFSET
COROLLA 88-02 14x5.5 4x100 12x1.5 54.1 H
JETTA 81-98 14x6 4x100 12x1.5b 57.1 H
I looks like the hub is a little bigger, and the jetta uses a bolt instead of a stud. Those should still work right?
10-05-2011, 06:35 PM
#9 (permalink )
you'll need hubcentric rings.
10-06-2011, 05:25 AM
#10 (permalink )
Nick
What about 13x8 with a +20 mm offset?
I know I'd have to roll a bit, but how much poke would I have? lol
-1994 Toyota Corolla-Ksport Coilovers, custom exhaust, Weapon R intake with Ram Air Kit
10-06-2011, 07:42 AM
#11 (permalink )
13x8 would be like a god damn steam roller (and probably only come in an offset for RWD, sticking WAY out like a Mexican low rider), and 18x3 would be like a motorcycle wheel.
10-06-2011, 07:47 AM
#12 (permalink )
Nick
Bitter
They come in an offset for fwd rims.
Its for Honda Drag cars xD
V2 Competition drag rims
10-06-2011, 07:41 PM
#13 (permalink )
Can you break traction with high performance street radials at the 1/4 mile? And no, 13x8 are for VW homosexuals with stretched tires. No way you can cram performance brakes, like a high output Honda would be running, inside 13" wheels.
10-06-2011, 10:26 PM
#14 (permalink )
on full afterburner
If you want 8" wide wheels, run 15s.
Better yet run 949racing 6UL's.
10-07-2011, 05:18 AM
#15 (permalink )
Nick
15x7 with a 40 mm offset?
For offset and I looking for 40mm to fit perfect without spacers?
Linear Mode
