Squeal from front suspension until I hit the brakes. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2011, 09:11 PM   #1 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
Anyone know what's up with that? Sometimes it comes back when I hit bumps and stuff. Usually doesn't make any noise, but sometimes does, and hitting the brakes a few times will make it go away. Brakes seem fine.
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 10-08-2011, 02:07 AM   #2 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179500
View Hiro Protagonist's Photo Gallery
By brakes being "fine", have you actually checked your pad wear? There will still be some meat left on the pads when the squealers start to make noise, sounds like you're at the stage when they _just_ start to make contact with the disc, which is why it isn't consistent.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is offline   Reply With Quote
Old 10-09-2011, 02:51 PM   #3 (permalink)
96 Toyota Corolla
kickfli12's Avatar
Gameroom cash: $134200
View kickfli12's Photo Gallery
i was having the same issue when i bought mine. turned out that when i took my caliper apart i had a stuck slide pin and was keeping the top part of my pad slightly pressed against the rotor until that part of the pad wore out. then when i would hit the brakes the noise would come back. the noise would also come back making right turns at low speeds until i straightened back out.
i have a factory spoiler for sale.
http://www.toyotanation.com/forum/66...ake-light.html
kickfli12 is offline   Reply With Quote
Old 10-09-2011, 09:01 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Squeaking on properly assembled brakes comes from rust on the backing plates and piston. Best cure is a permatex spray product that you spray on the pads. Ive used it successfully for years.
-SP
Old 10-14-2011, 05:42 AM   #5 (permalink)
BoyYota's Avatar
Thanks guys for all your input.
Maybe it was just the humidity/weather change?
It's been fine last few days.
