I have a 93 Corolla LE 1.8L 7AFE.
background: girlfriend blew motor, so put another motor with 91k on it in, compression is good in all cylinder, they read as follows: 123, 124, 125, 124.
idles find, but when under pressure like when in drive or reverse, it seems to missfire. when the engine is cold it does OK at best, then gets worse at it heats up. I cut the cat off and welded in a test pipe til i get it fixed, and the cat was very clogged when i cut it off. tonight I drove it around for a few miles and let it get to temp, and when it did, it started running like $#!& again, and I brought it home, popped the hood, and when it rev it up a little to see what it would do, and it just stalled. When I got in to restart it I saw that the CEL had came on (first time I have gotten it to come on), so I jumped the terminals and got the code. The codes it gave were:
31 - Air flow meter signal
41 - Throttle Position Sensor
Also when i tried to restart it, it wouldn't start, didn't look into it any more tonight after that. However, for one, what is an Air flow meter signal? I have never herd of this? For two, I have another TPS, and put it on today, and it didn't change anything. I am going to test to make sure they are good tomorrow when I buy a new multimeter since mine decided to die today. but this morning it idled perfect (i didn't drive it), and when I just dump the throttle, all it did was spit and sputter for a second, then revved to the limiter. If i slowly eased into the throttle, it ran fine.
I changed the coil already as well, unplugged the MAP (almost died when i did this, so I plugged it back in, just wanted to see if it made a difference). The battery and alternator are good, all sensors and pluggs are plugged up, cat is removed. I am at a dead end here, anyone ever had this happen, or know how to fix it? its been a month since i got the motor in, and I haven't been able to drive it!
