Ebay Header Corolla 1.8 and 1.6 Fit Problem
Hey all,
Had some good help on here when had issues with a water pump. Information was spot on!
So got that all back together. But there was always a slight exhaust leak so I figured I'd fix that at the same time. Turns out it's a cracked manifold.
So, did some research and found that what sounded like the cheapest and best solution was to go with an Ebay header. It looks like I have the 1.6 motor but from reading around here the 1.8 and 1.6 headers are interchangeable.
So ordered the 1.8 header kit as that seemed to be the only one available for a under a million dollars.
Got it today, tried to put it on. Bolt hole pattern is different.
Thanks.
