Ominous noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2011, 08:43 AM   #1 (permalink)
View Johnnny's Photo Gallery
gen 7 Ominous noise
Hi i was wondering if you could help me....my 95 Toyota corolla 1.6 l base model is making a clunking noise on start up, , and when i am driving it makes a vibrational noise that seems to be coming from the passenger side......i am wondering if it could be the timing belt, alternator pulley, or wheel bearing
any answers will be appreciated....Thanks John from Canada.
Johnnny is offline   Reply With Quote
Old 10-13-2011, 06:18 PM   #2 (permalink)
Nick
Gameroom cash: $156400
View TheNightWolf's Photo Gallery
Jack the front end up and see how much play you have in the wheels.
Just shake it side to side then up and down.
If you have no play, then your suspension should be fine.
Not sure what would cause a clunk on start up though.
-1994 Toyota Corolla-Ksport Coilovers, custom exhaust, Weapon R intake with Ram Air Kit
TheNightWolf is offline   Reply With Quote
Old 10-17-2011, 05:22 PM   #3 (permalink)
View bigd480's Photo Gallery
Check motor mounts - passenger side top one is prone to failure. The clunking could be the front one if it only happens when taking off in 1st gear. Mine vibrated like crazy until I replaced mounts.
bigd480 is offline   Reply With Quote
Old 10-18-2011, 02:51 PM   #4 (permalink)
View Shuttlepod One's Photo Gallery
Agreed - Clunking at start-up sounds a lot like a mount.
You definitely need to get under the car and start poking around with a pry bar. Find what's loose. Look for missing bolts while you're at it.
If nothings loose try supporting the engine with a piece of wood and a jack, then starting the engine. Noise go away? Probably a motor mount. Front is easy, side is not as easy, and the rear mount is a bitch.
Shuttlepod One is offline   Reply With Quote
Old 10-19-2011, 06:33 AM   #5 (permalink)
Thanks for the advice guys ill let you know...
Old 10-19-2011, 03:19 PM   #6 (permalink)
View JesusJones's Photo Gallery
Sway the car left to right while driving and see if the noise goes away when you do. When you go left if it goes away then the bearings on the left wheels are at fault. Turn right hard if the noise goes away its the right side wheel bearings. Bearings don't need to have any play to be loud as hell. They can also have lots of play and not make a peep.
JesusJones is offline   Reply With Quote
