Finally got to doing a compression check. Before I did my compression check, I warmed the engine up to normal operating temp, and floored the gas pedal while cranking it over. These are the results, I was shock!
Cyl #1: 40psi(This one is pretty bad; PSI dropping big time.)
Cyl #2: 135psi
Cyl #3: 120psi
Cyl #4: under 5psi
I say f*ck it, and I'mma drive it over the winter with only three cyl. It drives fine but just roughs at idle in "D". Sounds like a Subaru with exhaust with only three cyl. I disconnected the cyl #4 injector connector so it doesn't dump in fuel and f*ck up anything more. By Spring, I'll perform another 7AFE swap. Should have enough save up by then.
