need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2011, 10:22 AM   #1 (permalink)
blaxxx34
View blaxxx34's Photo Gallery
need help
hy.. ive got a 93 corolla 5afe engine.. ive changd fuel pump, fuel filter lead wires, tps , but my problem jus cant go away .. car spuuters an jus plain doesnt take gas at times.. .. if turn off car den turn on the ignition guess it primes the pump and if i start after tha the car works good for awhile put apart from da the car jus doesn take gas.. its not the fuel pump it works fine .. just dont understand whats cuasin this ..someoneplz help me
blaxxx34 is offline   Reply With Quote
Old 10-26-2011, 05:59 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Confirm that fuel pressure is correct. ANother possibility is the fuel pressure regulator. You'll know if its good or bad when you check the pressure.
-SP
Old 10-26-2011, 10:29 PM   #3 (permalink)
View NWMO 95 Prizm Lsi's Photo Gallery
blaxxx34,
If your fuel pressure etc. checks out, I'd look at the distributor next. I was chasing what I thought was a "miss" due to inconsistent fuel before taking the car (7 AFE) to a garage. They found the distributor was a reman. New reman distributors responded with similar problemS, finally got a junkyard dizzy and it's beet running strong ever since (14,000 miles).
Chris
NWMO 95 Prizm Lsi is offline   Reply With Quote
