Please help! Car won't start!
Hey guys. So my sister's car has been running rough for awhile now. Last night, she said it was stumbling pretty bad. I went out to check things out and when I pulled one of the spark plug wires, the connector was stuck on the plug and just the wire and boot came out. So now one of my wires was busted. Just to see if it made a difference, I started it up again. It actually sounded about the same, with maybe a little more harshness. I ran it on three cylinders for about a minute, then closed the hood. When I slammed the hood shut, the engine turned off. I tried firing it up again, but no luck.
Today, I went and purchased a new wire set and plugs. After I install everything, I try starting it up and still get nothing. I'm pretty sure my wires are hooked up correctly since I did them one at a time. All of the fuses are intact, and I don't see anything disconnected or out of place in the engine bay. I get a gas smell out of the exhaust after cranking it for awhile but it never tries to start. I'm not sure what else it could be. Please help!
94 Maxima SE 5-spd (daily driver)
81 Starlet (project car)
