1997 Corolla, Wheel Cylinder Replaced, Question on Bleeding
I just replaced the rear, passenger side, wheel cylinder on my 1997 Corolla. Prior to the fix, fluid was leaking freely out of the broken cylinder to the point of a near empty brake fluid reservoir. My question is which brake lines do I need to bleed? The one I worked on? The back two? or All Four?
So far, I have bled the one I worked on and I am able to stop pretty quick, but am not able to lock up the brakes. I assume that I should be able lock the brakes on this car pretty easy. If not, that would good to know too.
Thank you for help.
