engine swap failed emissions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2011, 04:41 PM   #1 (permalink)
View dosamstr's Photo Gallery
Hi,
I had a 94 prizm with a 1.6L
long story short, I had to swap the engine.
The new engine is a 97 corolla 1.6L
The car fails low idle hydrocarbons (HC)
I replaced the entire ignition system from the rotor to the plugs (still failed)
Ran a tank of guaranteed to pass. Failed worse than with just new ignition parts. (may have had up to a quarter tank left before refilled the tank, so some may still be in there)
My question is, (aside from how to fix the damn thing) its a 97 motor, if it were in a 97 car they would just plug in to the computer and say, ok no codes, no check engine light, PASS
or since it doesn't have a 96+ computer is that moot? .... could I go get a 97 computer from a junk yard?
details of the fail:
Low idle only, 330-380 HC when standard is 220. Other standards have never been a problem, passes high idle HC from 90 to 150 ( ranges are based upon the 3 tests)
dosamstr is offline   Reply With Quote
Old 11-01-2011, 08:21 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Could be a bad O2 sensor... or a Cat, lol... can't remember which one influences the HC's
Old 11-02-2011, 04:52 PM   #3 (permalink)
96 Toyota Corolla
kickfli12's Avatar
Gameroom cash: $134200
View kickfli12's Photo Gallery
O2 measures nox and the cat burns off the excess fuel reducing the ammount of hydrocarbons coming out of the tail pipe if im not mistaken.
i have a factory spoiler for sale.
http://www.toyotanation.com/forum/66...ake-light.html
kickfli12 is offline   Reply With Quote
Old 11-03-2011, 08:16 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
No, O2 measures oxygen in the exhaust which is an indicator of the air/fuel mixture that was burnt. The amount of O2 left over tells if more or less fuel is needed and the computer uses the O2 sensor to make adjustments in the mixture, always playing catch up with what's already happened.
A weak cat could cause high HC, so could a cold one. Before you get to the test go for a good hard drive, then keep the engine running fast in neutral while you're waiting. Hold it around 2000RPM for a few minutes before you test.
Old 11-04-2011, 02:38 AM   #5 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179500
View Hiro Protagonist's Photo Gallery
Complete opposite - the O2 or Lambda sensor measures the air-fuel ratio of the exhaust and tells the ECU whether to richen or lean the mixture - ideally the air-fuel ratio will be ~14:1 (called stoichiometric) and will result in complete combustion (minimising carbon monoxide) whereas a rich mixture will increase result in incomplete combustion and excess carbon monoxide and hydrocarbons in the exhaust. The cat gets rid primarily of NOx through a redox reaction as well as excess carbon monoxide and hydrocarbons through an oxidation reaction. Older cats used to only deal with the carbon monoxide and hydrocarbons in the exhaust, but they've been obsolete since the early 80s when the three-way (NOx, CO, HC) cats became standard (same kind of time that unleaded fuel came out, which made cats standard in most places in the world as 3-ways can't run on leaded fuel.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is offline   Reply With Quote
Old 11-08-2011, 12:58 AM   #6 (permalink)
on full afterburner
Gameroom cash: $1345597
Looks like you need a new catalytic converter.
Tags
engine swap, failed emissions, obd ii
