93 Corolla electrical problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2011, 06:49 PM   #1 (permalink)
View lunkhead's Photo Gallery
So, Monday night I was driving out to go on a halloween date and as i turn a corner my 93 Corolla driven hard with about 200k miles on it dies. Everything electrical cuts out and the engine dies about the exact same time.
I popped the hood and found that I wasn't getting any fire from the plugs so I go buy a new distributor cap and rotor (both needed to be replaced anyway so I figured why not). Replaced them and I'm still not getting any fire from the plugs. Odd thing is I think the battery and the cables are good because the starter is getting enough juice to turn the engine over fast enough for it to start and the stereo works so Im guessing just part of the electrical system is out.
I also think the fuel pump is working because I smell unburned gas after I crank it for a bit. I'm trying to find a wiring diagram but having some trouble (not sure where to look online) but i feel like it might be a bad wire somewhere or the coil just gave out. Any ideas?
Oh yeah and I checked all the fuses and they're good.
lunkhead is offline   Reply With Quote
Old 11-02-2011, 08:23 PM   #2 (permalink)
Gameroom cash: $110300
View fj62's Photo Gallery
Possible timimg belt??? How many miles are on your timing belt?
Dennis
2009 Highlander Hybrid, 2007 Camry, 1995 Corolla
Previous owned
1985 Camry, 1989 Land Cruiser, 1989 Corolla All-Trac wagon
fj62 is offline   Reply With Quote
Old 11-02-2011, 09:48 PM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
You checked the fuses BUT do you have power to the fuse box??
-SP
Old 11-03-2011, 09:29 AM   #4 (permalink)
Living on a Rock
kaitaiya's Avatar
Gameroom cash: $212950
View kaitaiya's Photo Gallery
only (free) wiring diagram i have been able to find is the one in the manual. it's not the greatest. i'm still looking for a better one. friend has a simular problem. trying to figure out his trouble i got his car cranking, but no fuel pump, no power to coil or injectors.
解体屋 Just a gearhead in paradise...
93 JDM AE102 20V Blacktop Blacktop Wiring DIY
The Somewhat tips and trick to the install
Proper Planning and Preparation Prevents P*** Poor Performance.
kaitaiya is offline   Reply With Quote
Old 11-03-2011, 03:28 PM   #5 (permalink)
Yes I did. Close to 200k but its intact.
-SP
Good question i just borrowed a multimeter so i'll know today.
Im about to go work on it i'll post an update in a few hours probably. Thanks for the help, everybody.
Old 11-03-2011, 04:18 PM   #6 (permalink)
Alright it lives
Tested the secondary stage of the old coil and the resistance was out of range; slapped on the new one and it lumbered to life. Knew this would be easier with a multimeter. Still couldn't find a wiring diagram for the vehicle (for free, anyway) but i can post the electrical specs of coil.
minimum primary resistance range: 1.1-1.7 ohm
minimum secondary resistance range 10.0k-15.0k ohm
and its a duralast C972 part number
Old 11-04-2011, 08:42 AM   #7 (permalink)
Living on a Rock
kaitaiya's Avatar
Originally Posted by lunkhead View Post
Alright it lives
how are you testing the resistance? ground to the outside?
Old 11-04-2011, 06:24 PM   #8 (permalink)
Andele, andele!
speedy25's Avatar
Unfortunately Autozone has a reputation for some really crappy parts. I hope yours at least lasts a while. If you have the same symptoms again someday it may well be that part again.
-SP
