Issue with a 96 4afe in a 93 corolla 4afe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2011, 01:45 PM   #1 (permalink)
View bagged cl's Photo Gallery
Hello, i did a little searching and could not find and info on this. I picked up a 96 4afe to install into my 93 corolla which i was told would fit with no problems as long as i switched over most of my parts over from the old motor, which for the most part worked but i ran into one problem, the two intakes are different, the newer block has a opening for emmissions going to the intake manifold and my older intake does not. My question is has anyone ran into this problem before and has a solution? I dont know if there is a block out plate or anything out there. Thanks for any help!
bagged cl is offline   Reply With Quote
Old 11-10-2011, 08:40 PM   #2 (permalink)
JDM wheel whore
View slowrolla's Photo Gallery
That is the EGR recirculating back into the manifold. Simply just use your old manifold or you can block it.
slowrolla is offline   Reply With Quote
Old 11-10-2011, 09:00 PM   #3 (permalink)
My old manifold doesn't cover it , it's left open . I was looking for a premade plate but looks like I am going to make one or maybe find a expanding plug. thanks any one else use this block?
